When I had an old furnace replaced with a new high efficient type gas furnace, the installer used 2" diameter PVC vent pipe, connected to the exhaust gas blower in the unit, extending straight up about 14' through the roof. When perusing the installation instructions, I discovered that the furnace manufacturer specified that 3" diameter PVC should be use to exhaust combustion gases. I am wondering, if in this case size matters, as to diameter of the vent, since the factory installed exhaust orifice at the furnace is 2" in diameter.
