Hi everyone...
The pressure in the upstream of our choke valve is said to be 309 barg. The upstream of the choke valve which is placed at nearly the beginning of this offshore plant starts from the wellheads to the choke valve...right!... so what I am concerned about is that, is this pressure constant all through the way -coming from the reservoir all through the casings and then the Xmas trees and reaching the choke valve-?
The velocity is of course high, therefore the differential pressure is high. Then the pressure of the fluid in two points of the line should differ from eachother.
How is it, that the pressure is mentioned as 309 barg at the upstream of the choke valve?
