Previous in Forum: Open Source Moon Mission!!!   Next in Forum: Heat sink less inverter
Drop less rectifier
04/20/2008 7:38 AM
Main disadventage of diode rectifier is heat and energy loss. If we use low rdsOn MOSFET instead of diode with proper gate drive we can safe energy droped in diode as well as reduce heat. Also we can avoid heatsink for diode
Re: Drop less rectifier
04/20/2008 8:42 AM
Mosfets can fail for no apparent reason and are very susceptible to voltage spikes...eg. from static discharge
Reliability would be a problem...I'd think.
Good Answers: 54
04/21/2008 1:28 AM
It's called "Synchronous Rectification" and is used everywhere. The rectification MOSFETs are also switched to lower inrush currents and reduce electrical noise.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Register to Reply 2 comments
You might be interested in: RF MOSFET Transistors, Rectifier Diodes, Power MOSFET
