Previous in Forum: Steel   Next in Forum: What's the highest wave you've ever seen?
compressor efficiency
04/21/2008 3:41 AM
how do I conduct experimental compressor efficiency
Good Answers: 19
Re: compressor efficiency
04/22/2008 2:27 AM
Install a Compressed Air Flow meter on Air Outlet, an Electrical Meter and an Hour Meter. Sit down, chart all data, make your graph and you will arrive at the efficiency.
04/22/2008 9:39 AM
You need to measure mass flow, pressure in and pressure out. Then calculate actual work on the gas as compared to the electric meter. This will give the over effiency of everything from the motor to the bearings to the gas compressor its self.
If you want to know the efficiency of the compressor you need to measure suction temperature and discharge temperature. Then get out the thermo books and fiquire it out.
Good Answers: 19
04/23/2008 11:22 PM
and fiquire it out.
I he can
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
09/05/2008 2:43 AM
You must count all parameres of compressor and trigger all information.
Look over to the next challenge
ducon (2); user-deleted-1104 (1); vicini (1)
