Previous in Forum: magnetic insulator   Next in Forum: Underground cable fault locator
Current and Flux density
04/21/2008 5:04 AM
Dear members,
I want to design a small autotransformer say 0.5kva. How much maximum current density can I use for super enamalled copper wire. In design books the maximum current density is given as 2.3A/mm2. If I am using this value, the size of the Xmer becomes almost double than commercially available Xmers of the same rating and the same is true for material and the cost. I am facing the same problem with maximum flux density for CRGO core. Please help
Some related web link will be useful.
Thanks in advance
Good Answers: 143
Re: Current and Flux density
04/21/2008 5:57 AM
I have always used about 700 CM/A which, if I do the conversion correctly, is about 2.8 A/mm2. This is essentially a continuous duty rating, which is what you need for a power transformer. By the way CM = circular mil.
I might be able to convince myself to go as low as about 550 CM/A with high temperature insulation and very good cooling. That would equal about 3.5 A/mm2, but I would not go beyond that ever.
As to the silicon steel core, there is no way anyone can double the maximum flux density since the typical design value will already be perhaps 85% of the maximum. There are higher value steels available. Perhaps the commercial unit is using this?
Can you give a little more specific information?
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
04/22/2008 5:04 AM
I don't know which country you are in, but I find that auto transformers sold in many countries in the Middle East, Africa, India etc. are much too small for their nominal rating and consequently run dangerously hot. I am not surprised they are half the size of the text book transformer. A final twist is to replace copper windings with aluminium without increasing the size.
04/23/2008 12:41 PM
Hi,
I am from India. That is what I am worried about. The commercially available auto transformers are very much small in size than what we get from books. But, ths is also a fact that not al these small sized xmers heat too much on load. I designed a 0.5kva xmer with the current density of 10A/mm2 (getting this max. value from the book "Electrical machine design" by A K Sahni), and the xmer worked ok. Too much confusing!!!!!!!
Good Answers: 143
04/23/2008 1:30 PM
You're essentially saying you ran 10 A through an 18 AWG wire, not in free air, and it didn't get hot. That's pretty good. Do you have any special copper you use?
04/27/2008 5:12 AM
Thanks for your comment. As I am a beginner in designing I don't mind about any strange comment.
Can you please check what is wrong in the following design? Any suggestions are most welcome.
7 step Auto-transformer
Power = 300 VA
Primary Voltage (Vp) = 90V
Secondary Voltage (Vs) = 230V
Core selected 3No., 2inch EI CRGO Stampings, Tongue Width (TW) = 3.175 cm , Window Area (WA) = 7.562 cm
Gross Core Area (Ag) = 3.175 * 2 * 2.54 cm2 = 16.129 cm2
Core Area (Ai) = 0.9 * 16.129 = 14.5161 cm2
Turns per Volt (Te) = 10^4 / 4.44 * f * B * Ai
= 10^4 / 4.44 * 50 * 1 * 14.5161
= 3.103 = 3 (appox.)
Primary turns (Tp) = 90 * 3 = 270
Secondary turns (Ts) = 140 * 3 * 1.05 = 441 (adding 5% for voltage drop)
Pimary current (Ip) = 300 / 90*0.95 = 3.508
Secondary current (Is) = 300 / 230 = 1.304
Effective current in Primary (Iep) = Ip – Is = 3.508 – 1.304 = 2.204
Taking Current Density = 5 A/mm2
Area of primary conductor (Ap) = 2.204 / 5 = 0.4408 mm2 (i.e. 22 SWG Cu Wire)
Area of secondary conductor (As) = 1.304 / 5 = 0.2608 mm2 (i.e. 23 SWG Cu Wire)
Space taken by primary winding = 270 / 176 = 1.534 cm2
Space taken by secondary winding = 441 / 242 = 1.8223 cm2
Total space taken = 1.2 (1.534 + 1.8223) / 0.6 = 6.713 cm2
Remarks: 1. Little bit heat up.
2. Little noisy after 200V.
Good Answers: 143
04/27/2008 6:15 AM
What do you mean by "strange comment"?
In your earlier post, you said you were using 10 A/mm2. In this detailed calculation, you're using 5 A/mm2. Now I'm confused about your question.
Register to Reply 6 comments
Abid (2); Chankley (1); TVP45 (3)
