Hello
I am trying to simulate a fluid heating curve from ambient to max operating temp. To accomplish this I have proposed a system with 2 tanks, one at ambient temp and the other at the max op. temp. The flow is moderated using two proportional control valves with a 4-20 mAmp input.
From there on the pipes meet at a mixing manifold and the mixed fluid is pumped for the simulation rig testing. the simulation rig consists of 3 tanks with constant pressure drop across each. now i need a variable flow (VFD) pump since i might decide to bring any compination of tanks online (one or two or all three).
The valves are controlled using a PLC which takes in inputs based on temperature of the three pipes (the two inputs and the final mixed temp). I need the final temp to follow a preexisting curve.
the min flow factor for the valves is 3 and the max is 15.
Heres the first question, does this absurd or quite doable? I have all the parts (quotes on them atleast) and i jsut want to get a confirmation before i order anything.
The pump is 1 hp end suction centrifugal pump (w/inverter motor) with rated flow capacity of 70 GPM.
The second question comes here. would a VFD work for the application im proposing. To maintain the flow rate im going to be using a differential pressure transmitter and a plc. or even input pre determined values into the vfd which just switches or just manual.
Does the whole system sound viable?
Im an engineering student doing my co-op at a company and well need help. Thank you, i really appreciate any response or assistance.
