Previous in Forum: x-ray image maker software   Next in Forum: CPU Fan is Suddenly Going Full Speed? What gives!?
On Blackfin Processor Programming
04/22/2008 5:59 AM
Hi,
I am using BF534 with many peripherals for my apllication... I am designing a board with Bf534 and several perpherals like ADC, DAC, LCD,SDRAM ,Flash memory, Buttons, VGA etc...........
I am controlling each of the peripherals using the processor...... I have built the interface conntrol source code for most of the peripherals......
But now I found that there is manual in Analog devices website called "Device drivers and Sytem sercvices for Blackfin processors"(Initially I found it difficult and so ignored it)...Now, I am not using that kind of programming for my application...... Is it OK??? I am dierctly programming the registers...For example
*pTIMER3_WIDTH =1000; //Program timer width register//
*pTIMER3_PERIOD=1000+7500; ///Program timer period register///
1) Which type of programming would be easier?
2)Which is more faster?
3)Is it OK if I continue in the same manner?
4)Which method is more efficient and ideal and used for controlling different perpherals?
5)How much time would I take more (in general) to learn and start programming based on the above mentioned device driver manual??
Thank you,
Kind Regards,
Nithin K S
Re: On Blackfin Processor Programming
04/22/2008 11:08 PM
High level, once you overcome the learning curve.
Yes, but you'll have to keep doing it that way until you...overcome the learning curve.
High level, though there may be times when there are no library functions for some of your peripherals so you still may have to do low level coding at times.
Depends on your level of experience and how important it is to you. If you are going to keep doing this kind of work you should make the investment.
You might be interested in: Device Programming Services, Programming Languages
