Previous in Forum: Captured O-ring   Next in Forum: full vaccume line
11 comments
66 feet
04/22/2008 12:45 PM
hi anyone thought much about compressed air from water drive to save to 'fuel' high pressure fluid drive"micro hydro" battery charger?
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: 66 feet
04/22/2008 1:31 PM
gravity,
A little more info plleeaasse.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Re: 66 feet
04/22/2008 1:57 PM
water turbine drive to compressed air to long distance 0 loss reuse as push in fluid drive power station winter summer high flow no flow
Re: 66 feet
04/22/2008 2:09 PM
I almost think I understand what you are trying so crypticaly to say. If you could spend just a little more time on the keys we might actually be able to communicate.
Re: 66 feet
04/22/2008 2:52 PM
do you think compressed air has the potential to be the greenest of power sources?
Good Answers: 266
Re: 66 feet
04/22/2008 3:41 PM
Greenest maybe efficient no.
Re: 66 feet
04/22/2008 4:01 PM
what does efficient really mean here, wasted what?
Re: 66 feet
04/22/2008 10:31 PM
How do you propose to compress this air? You have to get the power from somewhere.
Re: 66 feet
04/25/2008 10:19 AM
check out norton energy , seems other folks find it useful.
Good Answers: 101
Re: 66 feet
04/22/2008 11:41 PM
Are you thinking of using a hydraulic ram to drive a water-turbine?
Re: 66 feet
04/23/2008 3:13 AM
It's very difficult to tell what this poster is thinking.
Re: 66 feet
04/23/2008 6:23 PM
low head pelton turgo or francis trubine or ???? medium water wheel to compress air to use later at distant location for pressurized fluid drive power device IN SUMMER
pelton ,turgo ,francis, or high head system?
Register to Reply 11 comments
DVader1000 (1); gravity (5); ozzb (1); PWSlack (1); Shadetree (3)
