Do you know the math in order to calculate the voltage raise in the other phases of a delta-delta power transformer when a short to ground occurs ? . For example, in the secondary, one leg of a 440 VAC 3 phase shorts one phase to ground. What voltage I will see in the another 2 phases ?. Take note the the secondary is NOT grounded. Primary voltage is 23 KV.
Thanks in advance.
francisco Sanchez
Faraon34@hotmail.com
