Previous in Forum: Melting and silver casting   Next in Forum: Metal Detectable Plastics
Raw gold nuggats/dust test
04/23/2008 5:29 AM
How to check purity of raw gold nuggats and dust?
Re: Raw gold nuggats/dust test
04/23/2008 7:43 AM
Mass Spectrometer?
04/23/2008 8:02 AM
Girlfriend?
Trust me. It's uncanny.
04/23/2008 11:27 AM
Taking up hobby gold prospecting eh?
You can easily check the bulk density of your nugget by its displacement in a known volumetric cylinder right at the stream. And with gold dust just keep it in a bag and check it at home on a scale or according to its settling rate in water. Gold dust can be a bit tricky especially if your stream bed or ore body has a lot of pyrite or dark micas in it, but it will fall out of solution quicker than the pyrite and considerably quicker than the mica.
All this worldly wisdom was once the unamiable heresy of some wise man. -Thoreau
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
04/23/2008 11:57 AM
Naveel,
The standard method of checking the purity of gold s referred to as a fire assay.
The fire assay of gold ore consists of two stages:
In the first stage, a sample of the gold (of precisely known weight) is made to combine or alloy with metallic lead (forming a metallic bead or "button"), with the the other constituents of the ore being separated from the lead as slag;
In the second stage, the lead button containing the gold is cupelled (to oxidize and remove the lead constituents), and the resulting gold button is weighed. Comparing this weight to the weight of the original assay sample yields the gold content or "purity".
Just my $0.02...
Register to Reply 4 comments
Anonymous Poster (1); Ben Bonsens (1); PWSlack (1); The JMAN (1)
