Previous in Forum: Generator output power   Next in Forum: VSD 4-20ma
electronic ballast solution
04/24/2008 2:19 AM
i want to develop 2x54w t-5 lamp ballast so i want the scematic and bom for that
Good Answers: 140
Re: electronic ballast solution
04/24/2008 7:55 AM
The process you are interested in is known as "designing".
Here is a link for you for you to use...
http://en.wikipedia.org/wiki/Designing
04/24/2008 9:19 AM
Personally I've never heard of a T5 fluorescent tube rated at 54 watts?????
John.
04/24/2008 11:23 AM
There is some thing known as a fee for doing such jobs and persons known as consultants.
04/24/2008 6:03 PM
If you look around, you should find there are IC manufacturers which make ICs that are specifically designed as fluorescent ballast controllers and they can help you with the design work. One such company is International Rectifier aka "IR" (which, by the way, I'm not particuarly endorsing). In fact, if you look around on IR's website they even offer a FREE bit of software which basically prompts you to plug in your lamp specifications, your line voltage and what sort of ballast topology you want. It then spits out a schematic, a BOM and even the specifics on the transfomers / inductors that you'll need. Rather neat.
Hey International Rectifier! Please be so kind as to deposit the usual amount of money into my Swiss bank account. Thanks!
Anonymous Poster (1); Electroman (1); nesubra (1); North of 60 (1)
You might be interested in: Ballasts, Lighting Fixtures, LED Lamps
