when two generators are working in parallel (A,B) with identical electrical supplies.
which device automatically controls the fuel supply to the generator prime mover?
Increasing the fuel supply of one generator prime mover will_________the active power supplied by the generator and as a consequence the active power supplied by the other generator will___________?
if the fuel supply of the other generator prime mover is unchanged the busbar frequency will_________?
increasing the excitation of one generator will________the reactive power supplied by the generator,_________the generator load current and ________the generator power factor.
as a concequence the reactive power supplied by the other generator will _______,its load current will _________and its power factor will______.
if the excitation of the other generator is unchanged the busbar voltage will______?
to maintain the correct busbar voltage the excitation of one generator must be_________ and the excitation other generator must be simutaneously________?
please help me>>>>
