Previous in Forum: formulue   Next in Forum: Thinking About Building Something That Can Detect Poly Pipe
Good Answers: 18
Calculation-Boundary Layer Thickness
04/24/2008 4:22 PM
I am looking for a text (or published article) which gives specifics on how to calculate the thickness of the boundary layer (BL) that would be carried on one side of a strip (say a steel strip) of width (W) traveling vertically at a speed (V) out of a water (or aqueous) bath. Which specific parameters for the strip material* and physical properties of the solution are critical, and specifically how does one calculate the BL thickness. Basically, I am interested in a text (or alternative) that gives a "sample calculation" if possible. This topic may potentially fall into the area of aeronautical engineering, I'm not sure.
* obviously surface roughness and surface tension might be included.
Re: Calculation-Boundary Layer Thickness
04/25/2008 7:36 AM
hey DEAR U can concern AK jain AND GARDEY BOOK in fluid mechanics . u will find the calculation and concept regarding BOUNDARY LAYER THICKNESS IN THAT BOOK.
Good Answers: 18
04/25/2008 12:35 PM
Please can you provide more details on the fluid mechanics text you mention such as IBSN Number, or publisher, etc. I have tried to Google it and find no references.
Thank You,
Agua_doc
04/25/2008 12:54 PM
Try OPAMP Technical Books in Los Angeles.
http://opamp.com/index.html
Register to Reply 3 comments
agua_doc (1); amit_agarwal814 (1); pantaz (1)
You might be interested in: Metal Strip, Stock and Strip Feeders, Strip Heaters
