Previous in Forum: mini blast furnaces of 128M3 volume from china etc   Next in Forum: Heat exchangers and Nuclear reactors.
11 comments
A Data Center Room Partition
04/28/2008 4:28 AM
We have divided our raised floor areas into 2 different IT companies. Both of them will install their own data center for office purposes. But for that, they demand a secure partition, from below the raised floor up to the slab above the ceiling. Is anybody know what kind of partition we should build? Any reference's website? Thanks
positive mind always constructive
Re: A Data Center Room Partition
04/28/2008 10:39 PM
You can get 'cages' for this purpose. Where abouts are you in the world?
04/28/2008 11:05 PM
I don't know, but they demand a separate M/E eq, including the precision AC too, ouch...
Btw, we're somewhere in South East Asia.
04/28/2008 11:19 PM
Maybe if your datacentre is quite small you go simple and buy keylockable racks with different keycodes, or probably better still, with a keypad, so you can set up your own codes.
In Australia look at http://www.brdatasystems.com.au, or there are plenty of rack manufacturer in SE Asia that I'm sure would supply with keypads if you ask.
04/29/2008 12:31 AM
Infact, each room after separation is about 100sqm. The policy was we only support the electricity (the power in that matter), so they can adjust all system independently, including AC. So, they demand a good secure partition as I mentioned before. So, the secure rack thing won't work, but after your reply first time, I have an idea. Maybe, they'll accept the cage (for the security reason, thanks for it) but with solid alum panel finishing (for a stronger but slim separation). Any product like this?
Thanks....
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
04/29/2008 7:38 AM
Try honeycomb aluminum with finished sides. Strong thin and lightweight. Good stuff.
If necessity is the mother of invention then is laziness the mother of necessity?
04/29/2008 8:20 AM
Thanks.
Any ref website ?
04/29/2008 9:51 AM
04/29/2008 10:52 AM
Let's count:
- You have to divide the room to two same size parts: you have to ensure a fireproof separation and it can be useful if the wall could give a sort of thermal insulation. In addition, protection against electromagnetic emanation can also be useful. You also have to ensure the isolation under the raised floor. A metal cage covered with dry wall on both side can be sufficient.
- You have to ensure the independent power system. That means that you will have two UPS systems
- You have to ensure the independent air conditioning, so you will need to duplicate the AC system
- You will need two, independent connections to the local telco/WAN provider so you will need two uplinks
Aged man is not old man...
04/29/2008 12:37 PM
2 X spaces; 2 X UPS systems; 2 X AC mains; 2 X WAN links; add 2 X separately keyed door locks, so that's 10 pieces. Sounds about right...
04/29/2008 10:27 PM
<In addition, protection against electromagnetic emanation can also be useful.>
Can u explain more about this, is it including microwave? Shall I go this far? How to know eitherway? Is the material like an absorber sheet?
06/02/2008 3:56 AM
It sounds like what you are building is a clean room.
Then Aluminum Honeycomb Panel is the best choice for your partition.If you would like to buy from us,then please visit our website www.atbond.cn
To memorize the passed children in the May.12th Sichuan earthquake disaster...
Register to Reply 11 comments
double_j_b (1); EnviroMan (2); funkyg (2); keanu916 (1); Qqberci (1); rino syahrir (4)
