Previous in Forum: Diffusion Coefficient   Next in Forum: How Do I Start A Service Of Removing Sedimentation From Big Petroleum Tank?
charring sugar
04/28/2008 4:01 PM
We are interested in charring table sugar (sucrose).
Are there any additives/catalysts that can alter the process conditions (i.e. time to char, temperature, product yield)?
Michael Binder
Pathfinder Tags: sugar char
Good Answers: 101
Re: charring sugar
04/28/2008 9:21 PM
Are you planning to turn the sucrose into carbon, or just caramelize it? If you're planning to turn it into carbon, a small amount of concentrated sulfuric acid, a powerful dessicant, will do a very effective job of it.
Good Answers: 109
Re: charring sugar
04/29/2008 3:40 AM
Hi,
there are some residuals from crystallisation and bleaching of ordinary sugar that you won't like in ultrapure carbon.
There may be very likely other contaminants in the sugar from residual natural minerals and may be some leached metallic contaminants from the process equipment.
Considering the carbonisation process - estimated to run in vacuum? - where and how to remove the hydrogen?
How is heating accomplished?
What about heat transfer inside the sugar melt?
What about heating rate and final temperature and time?
You can get anything from a very hard and brittle and mostly amorphous "pyrolithic" carbon that contains traces of hydrogen to porous carbon, to cracked carbon grains with porosity to partial or total graphitisation.
Any material that will bind to hydrogen will accelerate the process. But not likely to be existing with very high purity. So why?
What is your preferred product shape to facilitate the next step? Grains, chunks, powder? (To avoid crushing?)
What is the intended production rate?
Have success, difficult topic!
RHABE
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: charring sugar
04/29/2008 2:21 PM
Concentrated sulfuric acid will char (dehydrate and oxidize) sucrose. But you might not find such a method useful since, depending on your application, you might not want your product contaminated with sulfuric acid.
http://www.exo.net/~pauld/activities/astronomy/transitvenus/sugarsulfuricacid.htm
http://www.youtube.com/watch?v=gPGRtUPyvs8
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
Register to Reply 3 comments
DVader1000 (1); RHABE (1); svengali (1)
