Previous in Forum: dust collector   Next in Forum: PID Tunning
Test Samples Selection
04/28/2008 11:51 PM
Test Sample Selection :
Hi, I would like to know about the test samples selection of EUT`s when it is to be placed in Highly Accelerated Stress Testing Chamber?
Re: Test Samples Selection
04/30/2008 12:00 AM
Test sample selected should be selected RANDOMLY only. Otherwise, you will not get representative results.
For defining number of samples to be tested, (sample plan), there are International/ national standards. This depends upon many things, including your batch quantity and risk factors
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
04/30/2008 7:56 AM
Dear Guest -
a) if you get time, it might be worth your while to register, and tell us a little more about what it is you would like to accomplish - minus details it is hard to help other than to give you the most general direction
b) gsuhas is correct - a random (continual not continuous) sampling will need to be generated and tested - and the resulting data should be incorporated back into your process capability to understand what if any additional 'control' you have on the outcome - I'm wondering how many significant posts will happen in this thread before it wanders off topic -
c) I suspect this group will get into a big discussion about 'random' in general -
let me offer a couple of manufacturing thoughts to help open up your quest a bit -
1) 'truly random' against a standard AQL random testing procedure could have you select the first, say 125 parts out of 2500, run your tests, accept on 7 bad, reject on 8 and then put all the parts good and bad back into the containers for shipping - or it could be the last 125, or one every some many except when divisible by 7 etc - random is a tough idea to get across; and then the randomness in box two might be a different sampling variation with the same acceptance criteria.
2) on the other hand - the first 125 pieces in a box are not truly representative to any great degree of the last 125 going into the box, unless you have established that the PROCESS is both 'capable' and 'stable' - here were some other threads discussed and offered up by bright CR4'ers previously about process capability discussion as well -
http://cr4.globalspec.com/thread/15149/Process-Capability?frmtrk=CR4digest
http://www.qualityamerica.com/knowledgecente/articles/cqeIVH4_1.htm
