Previous in Forum: earth pit v/s MVA rating   Next in Forum: Battery charging
10 comments
I Am Looking for SS Banana Plugs
04/29/2008 5:43 AM
Hello,
I am looking to find a source for these connectors.
Any help in finding them would be appreciated.
Richard
Re: I am looking for SS Banana Plugs
04/29/2008 7:48 AM
Re: I Am Looking for SS Banana Plugs
04/29/2008 9:06 AM
It's a good idea when posting a photo like this to give something for scale. Best not to use a coin, as it's too localized. Ideally, include a graduated scale (and made sure it's obvious whether it's mm or inches or whatever).
Am I right in thinking these are 4mm plugs?
04/29/2008 9:50 AM
Good point John; the fingers measure 3/16" in dia., total length with barrel on is 1 3/8".
Richard
04/29/2008 9:58 AM
What's the biggest twist drill shaft you can (comfortably) fit into the socket? It's always difficult to measure the diameter of something like a banana plug.
4mm is a standard size - 3/16" is about 43/4mm.
04/29/2008 10:27 AM
The socket size is 5/32".
I do appreciate your help.
Richard
04/29/2008 10:55 AM
Yup - that's 4mm!
Just got to find a supplier, now!
I'll have a look around - suggest you do the same. Whoever gets there first, post it here.
Regards, John
04/29/2008 11:25 AM
Ok will do... much obliged.
05/01/2008 12:03 PM
Ok... the source is Lignomat; www.lignomat.com or Brunner Hildebrand www.hildebrandbrunner.com . I can tell you they are not cheap! $7.80 each USD.
Surely there is a connector out there that is cheaper and will hold up to a kiln's environment. Max temp is 180 f and humidity at times has to be close to 100 %.
If anyone has any ideas I am open to suggestions.
Richard
05/01/2008 1:28 PM
Glad you found it - I didn't get far. I was close to suggesting you contact a local engineering shop & getting a price for them to make the backshells - you could probably use the plug part from something fairly cheap (throwing away their plastic backshell).
I saw some around with backshells that looked mostly metal - you'd need to check out the temp & RH spec for the plastic bits. I think the main problem is that the backshell is almost invariably insulated from the working end.
04/30/2008 11:12 PM
Banana--you sound like a banana--Kidding, of course. Just wanted to get in touch with you and let you have my user name, Brother. Thanks for the link.
Register to Reply 10 comments
Brother (4); JohnDG (4); PWSlack (1); user-deleted-7 (1)
