Previous in Forum: Steel Truss Water Tower: Stability Questions   Next in Forum: Industrial Coating and Painting Services
Virtual Computational Chemistry Laboratory
05/02/2008 11:51 AM
I have started learning computational chemistry. I wonder the benfits that computers bring to understand the wet chemistry. What is it really? Anybody with some more introductory informations. A PDF file or a web page may help. I have also recently read about Virtual computational Laboratory. What a Clean way of doing chemistry if that means so? Lets discuss the Science here. I hope some experts in the feild. Thanks
Pathfinder Tags: Computational chemistry
Re: Virtual Computational Chemistry Laboratory
05/03/2008 12:24 AM
"Virtual Computational Chemistry Laboratory"
The students dream! "The Ultimate Dry Lab!" No more messy chemical stained notebooks and all that goes with wet lab experiments.
05/03/2008 10:29 PM
Yep, sounds like a easy (read "lazy") way to learn chemistry. Sounds like the good old American way... Too bad you can't learn things like chemical safety form computers. Like the time I learned not to dump a benzene containing system on fire into a sink which accidentally contained benzene and almost burned the chem lab down.
05/03/2008 7:25 AM
Hmmm,
Sounds interesting. First design your experiment. Then construct a virtual model. Put the model on a computer. Vary the variables. Observe the outcomes.
Then test your model and outcome(s) in a wet lab to verify.
Bobguz
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
05/25/2008 7:06 AM
Thanks bobquz;
That what I am upto. can you give just one example that shows an experiment designed where a virtual model is constructed on a computer and this has been used to observe the out comes of a certain change in some variables.
Register to Reply 4 comments
Anonymous Poster (1); bobguz (1); Dr. Girma (1); Stirling Stan (1)
You might be interested in: Laboratory Controllers, Laboratory Freeze Dryers
