Previous in Forum: Inflatable Space Station Prototype Launched   Next in Forum: Supercomputer, Black Holes and Aircraft Design
Spain - Member - New Member
Aerojet's NEXT Ion Thruster
07/21/2006 9:31 AM
Traditional chemical rockets may be a thing of the past. The dawn of "electric propulsion" is here (OK, enough hyperbole).
Aerojet has provided NASA with a new engine dubbed NASA's Evolutionary Xenon Thruster or simply, NEXT. NEXT is designed to provide three times the thrust of the previously used NSTAR ion thruster used on the Deep Space One mission. It will provide much greater fuel efficiency than NSTAR (+30%) and will require less than 10% of the propellant needed by conventional chemical rockets.
NASA views NEXT as an important step in the evolution of its deep space mission program.
Just like regular Elvis...only smaller.
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
NEXT Ion Thruster
07/24/2006 6:00 AM
One must remember that the amount of push (the thrust) of the ion engine is very tiny. The specific impulse (momentum change per unit of propellant) is quite high. So they will not replace the chemical rocket for lift-off, but can already do so for long distance travel.
Reply to Forum Thread
