Previous in Forum: The uncertainty principle   Next in Forum: HOW DO I CLEAN TARNISHING FROM BRASS MODEL ENGINE?
Desperately seeking riblet film.
05/11/2008 12:58 AM
I'm looking for a source of "riblet film". The research I have done always leads me to studies done by NASA, aircraft applications by Boeing and its use by the racing yacht Stars and Stripes. The source reference mentioned is "many companies including 3 M." I have not yet contacted 3 M, but going through their product list, I have not found this product (although going through their extensive product list has awakened many new ideas. It's worth a look). I almost think it is proprietary because of its connection to an America's Cup competitor.
Has anyone used this stuff and who would be a supplier? All it is is an embossed, self adhesive, some sort of plastic, sheet. But the size of the riblets, I'm sure, is critical.
Nothing exceeds like excess.
Re: Desperately seeking riblet film.
05/11/2008 11:02 PM
That's the film that makes boats slip through the water like dolphins skin? Will it be available soon? What efficiency does it give? What efficiency would we get if we put riblets on the outsides of rockets, used plasma electrodes that reduce drag by 30 to 50%, reduced their weight with carbon nanotubes by 90% And substituted pulse detonation engines that weight less and that get 30- 70% better efficiency? What speed and takeoff payload could be achieved in a rocket or orbital space plane? If we pulled out all the stops and used every trick in the book we could probably make a resusable spaceplane. Anyone have time to do the calculations?
05/12/2008 8:57 AM
Information I have found seems to fall around 8-10% reduction in drag in both air and water craft. Doesn't sound like much but when you consider the energy in, it is something for relatively nothing. And except for occasional cleaning, no maintenance. I haven't heard of its use in F1 though and those guys are on top of everything. Does anyone know if it is being used on aircraft?
Good Answers: 18
05/12/2008 8:54 AM
I remember reading about this material probably 15-20 years back and wondered whatever happened to it. I could be a major energy saving product if it ever gets fully developed.
Good Answers: 150
05/12/2008 9:16 AM
It is my understanding that 3M sells it for use on aircraft, I am not aware of them selling a watercraft version (the geometry I would expect to be slightly different than the aircraft version due to the different Reynolds numbers). You can try contacting them directly:
http://solutions.3m.com/wps/portal/3M/en_US/WW/Country/Corp/Contact/
I'm not finding a entry on 3M's website, it may have been a one-off batch for research purposes. the thing is, would the drag reduction be enough to overcome the weight penalty of the film? And how do you handle seams? How robust is the adhesive? most plastic films and adhesives are attacked by UV and water. What happens when the film starts peeling off?
Who is John Galt?
Register to Reply 4 comments
agua_doc (1); Anonymous Poster (1); Jaguar (1); Rorschach (1)
You might be interested in: Thin Film Materials, Thin Film Sources
