Previous in Forum: ''repair of abb plc''   Next in Forum: Telemetry System
Hydraulic Control Valve
05/12/2008 8:00 AM
I am looking for a Globe gate Valve, manual Hydraulically operated. i want it fitted with a manual hand pump. could anyone help where i can obtain this
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Hydraulic Control Valve
05/13/2008 5:30 AM
Hi Mulenmar
Yes, we can help you but.........please can you clarify your requirements. Do you need:-
a) A gate valve for hydraulic use that is manually operated?
b) A gate valve that is hydraulically operated for other uses?
c) Size, taking into consideration, pressure, flow and acceptable pressure drop?
d) None of the above?
If you can give any indication of the valves intended purpose and also, where geographically that you are located, it would help the CR4 gang to point you in the right direction.
We await your reply!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
05/13/2008 5:43 AM
we are look for Cast steel gate valve sizes 10" to 20", Material Cast steel. this will be used for slurry. The valve should be hydraulically operated, but the condition does not allow to set up an hydraulic system. This will be positioned in a bush. so what we require is a hydraulic hand pump fitted to the actuator or valve, like car hydraulic jack. in this situation, the ram from the jack goes staright to the valve. our location is in Africa, Zambia.
05/13/2008 7:28 AM
Go to the link below, they manufacturer a self-contained hydraulic package for ball, gate and globle valve that has a manual hydralic pump that requies no power.
http://www.emersonprocess.com/valveautomation/Bettis/Products/PressureGuard.htm
Register to Reply 3 comments
Actuator Guy (1); Anonymous Poster (1); Beej50 (1)
