Previous in Forum: Ammonia removal   Next in Forum: What are Crystalline and Non-Crystalline materials?
9 comments
Engineering Fields - Civil Engineering - New Member
related t ocivil and chemical engineering..
05/13/2008 7:22 PM
Though Aluminum has relatively low strength,It has significant application in field of engineering-Give reasons.
Good Answers: 230
Re: related t ocivil and chemical engineering..
05/13/2008 7:26 PM
Hello aditya goyal
Is this a homework or Class Question?
Kind Regards....
05/14/2008 7:38 AM
Maybe you offer your ideas and we'll tell you if you're right.
As a hint...maybe compare it's properties against those of mild steel, consider such things as weight, strength, corrosion resitance...can it be alloyed? electrical conductivity, cost, machineability, ductility, colour/finish, thermal conductivity, availability, recycleability, edibility,flamibility,meting point.
Have you got the idea yet?
Good Answers: 243
05/14/2008 3:53 PM
Del, you didn't give any hints related to metallic properties like malleability,
Oh I get it.
milo
05/14/2008 4:43 PM
I did mention ductility... maybe Aditya can explain the difference between the two ?
Good Answers: 243
05/14/2008 4:47 PM
I knew you were off your rations when I saw edibility.
Milo
05/14/2008 5:27 PM
Nice to know someone is actually reading my posts .. I like a nice red herring.
Good Answers: 230
05/16/2008 6:40 AM
Hello Del the cat
Just for you
kind Regards....
05/14/2008 1:31 PM
The aluminum pole is used the the Festivus holiday even because it has a high strength to weight ratio.
http://en.wikipedia.org/wiki/Festivus
At least that is what Frank Costanza claims.
05/16/2008 7:21 AM
Dear Aditya Goyal,
Does your diploma say "Close cover before striking match?"
Mike
Register to Reply 9 comments
HapE2bhere (1); healybj8 (1); Milo (2); Sparkstation (2); user-deleted-1105 (3)
