Previous in Forum: What Contests Exist to Promote Green Ideas?   Next in Forum: DVD's for $30
Philippine Case Studies #4 & #5
05/14/2008 7:30 AM
01. Would BioGas Technologies (APIX et.al) be appropriate in these cases? Consider:
  • Case Study # 4 - Small Farming. Prospect Client owns an 8000 sq mtr Farm Lot planted to Coffee & Coconut Trees. He also have 20 Goats + 500 "Free Range" Chickens. He plans to have another 100 Pigs for Fattening - soon. He now uses Compost to fertilize his trees;
  • CaseStudy # 5 - Garbage Trucker. Metro Manila could have about 10 Garbage Trucking Contractors similar to this Case Study #5. Other Garbage Truckers could be dumping theirs in nearby Landfills. Consider: One Garbage Collector-Contractor operating in Metropolitan Manila owns a 1500 sq mtr Materials Recovery Facility (MRF) and has Lease Rights on an adjacent 2000 sq mtr non-fenced Lot - both, located about 1 km away from the Laguna Lake. In the daily rounds of his Garbage Trucks, Non-BioWaste (bagged separately "at-source") are sold to "Junk Shops" for ultimate delivery to Industrial Users. Sales Revenue from Non-BioWaste is "Extra Income" for his Garbage Truck Crew. Only BioWaste are brought to his MRF Site. Consider:
      • Kitchen Wastes - About 5000 ltrs daily (mostly coming from Household & Industrial Kitchens) are brought to his MRF - and are then taken freely at no cost as Hog Feed by the Urban Poor Households residing nearby;
      • Tree Cuttings - About 2 Truckloads (10 tonners) are collected daily and brought to the MRF for shredding (by his 2 Shredding machines) - and treated with enzyme for ultimate decomposting as Organic Fertilizer for sale.
02. I await reactions &/or suggestions.
Mortal LIFE is all about Time Management in the Service-for-Others for the glory of GOD here on Earth.
Re: Philippine Case Studies #4 & #5
05/14/2008 7:49 AM
Garbage Trucker sounds like a smart guy.
Could those tree cuttings also produce gas as they are composting down.. (Also heat...but I don't s'pose they need any more heat in Manila?)
This report makes garbage collection sound actually exciting...
APIX Pilot Plant Design Project - Member - New Member
05/14/2008 11:28 PM
Ernie,
Both fall directly into the bio-digestion area but in different ways.
Case #4 would use a bio-digester like as proposed in Case #3 for barn cleanup after Goats and pigs. It would be difficult to collect free range chicken droppings unless the roost at night in a "hen house". The effluent from the manure bio-digestion is an excellent fertilizer for his trees and is equal to the composted manure he is currently using.
As for the "cured" coffee bean shells, they too can be collected and digested, but it might be better to use a Siemens type gas generator. This would also work for the downed trees, tree trimmings and weeds collected in the coffee and coconut plantation. You do not say whether the farmer processes the coconuts, but the coconut shells could also be passed through the gas generator. Since the gas generator works by putting high pressure steam at 1000°F or there abouts to "reform" the carbohydrates to produce hydrogen, methane, and carbon monoxide, I would suggest you obtain a Siemens type SOFC and use the heat generated to drive the gas generator. This is very similar to the schema I am proposing to the City of Houston, Texas with my HARP-SEProject. I am sure that the people with Agro-Biogenics can work out the material and heat balance for you or you can contact Siemens and ask them for a quote/bid on the system.
For case #5, the same principles apply, for the kitchen wastes (also human and animal wastes)can be made quite safe with a properly designed bio-digestion system. With this schema, again, the effluent can be made it to a high quality and marketable fertilizer. If designed correctly, the effluent can then be drained into the Laguna lake, however, the effluent should be tested on a regular basis to be sure that there is no upset in the system.
For the solid wastes, after the Materials Recovery Facility, the solid organics such as paper, baby diapers, tree limbs, grass clippings, etc. can go into a gas generator and SOFC/GT Hybrid system for electric power generation power generation. Again, you can ask the Agro-Biogenics Corporation for details or you can ask Siemens or other similar companies for quote/bids.
chtank
05/15/2008 6:15 AM
Charles,
Thanks for your inputs. Regards.
Ernie
Register to Reply 3 comments
chtank (1); manilaman (1); user-deleted-1105 (1)
You might be interested in: Incinerators, Chutes, Shredders and Grinders
