Previous in Forum: Saving MPG with Brown Gas Generator   Next in Forum: Plastics with memory
Venting HP gas: tubing specn.
05/14/2008 11:18 AM
We are installing a panel which has a number of valves to allow a pump to pressurise Nitrogen gas to 15,000 psi (1034 bar).
We want to run the vent (bleed off) lines into the existing pipework which is 1/2" OD x 0.064" wall x 316SS tube.
On the previous system we installed I used the same specn tube as for the HP test i.e. 20K rated 3/8" OD x .203" ID.
I am concerned that should the icing during venting up close up the bore of the 1/2" tube so that back pressure could build up and burst the pipe, or will the velocity allow the bore to be maintained to prevent this?
help please
Re: Venting HP gas: tubing specn.
05/14/2008 11:21 PM
guest; do not be cheap! go to 2" pipe, no problems perry
05/15/2008 7:45 AM
So, why not rate the discharge pipe to 15,000psi, and not worry about it bursting?
