Previous in Forum: Engineering Polls   Next in Forum: Describe Future Non-Renewable Energy Sources
Sense and Count Circuit
05/15/2008 12:06 PM
I have an assignment to design a Counter Circuit for a Overlock Machine (SOCKS) in which a sensor sense every (CLIP=a part cut from the sock looks exactly like a shape of rubberband) produced by the machine and counts every clip when came out from the machines...
So the question arises, what type of sensor i used which sense the cutting part from the sock? secondly how i create the counter which counts such a huge amount of counting ?
Given:
1) In one minute almost 60 Clips cut off from the socks and out from the machine.
2) Machine contineously running to 8Hrs so it produces approx 5000/clip... so counter must reach up to 5000 counts and show the status on the LCD.
Assistance:
Kindly assist me as soon as possible, and if somebody gave me the complete circuit diagram i shall be thankful to him, i hope everybody clears the whole situation..
Awaiting your quick Response...
Regards,
Zohaib Moazzam Khan
Re: Sense and Count Circuit
05/15/2008 2:16 PM
I won't give you a complete circuit diagram, but I'll make a few suggestions:
1) micri-switch, optical or hall effect sensors on the cutting mechanism.
2) or, use the signal that actuates the cutter to count
3) 5000 is easily accommodated with a 13 bit counter, and 5 LCD digits.
05/16/2008 2:14 PM
This a datasheet for an Omron counter. They have many types, most of which will count well above 5000. Usually only need a closing contact to increment.
Regards,
Keywalker
p.s. you can also get programmable counters with batch counting capability.
Always use protection.
Register to Reply 2 comments
