Previous in Forum: cable size   Next in Forum: Cost of Generating Electricity by Diesel Generator
Vector group
05/19/2008 8:46 AM
May I know the difference between Dyn 11 or YynO of Transformers.
Re: Vector group
05/19/2008 9:55 AM
In Case of Dyn11 - Phase displacement b/w windings is 30deg
In case of yyno - Phase displacement will be "o"
Just keep in mind clock position.
Re: Vector group
05/19/2008 11:23 AM
ADVANTAGES OF THE Y-Y CONNECTION:
1. The primary and secondary circuits are in phase; i.e., there are no
phase angle displacements introduced by the Y-Y connection.
2. Since the phase-to-neutral voltage is only 57.7% of the phase-to phase
voltage, the windings of a Y-Y transformer require fewer
turns to produce the same level of excitation in the core compared
to windings connected across the phases.
3. If the neutral end of a Y-connected winding is grounded, then there
is an opportunity to use reduced levels of insulation at the neutral
end of the winding.
DISADVANTAGES OF THE Y-Y CONNECTION:
1. The presence of third (and other zero-sequence) harmonics at an
ungrounded neutral can cause overvoltage conditions at light load.
2. There can be a large voltage drop for unbalanced phase-to-neutral
loads.
3. Under certain circumstances, a Y-Y connected three-phase transformer can produce severe tank overheating that can quickly destroy the transformer.
4. Series resonance between the third harmonic magnetizing reactance
of the transformer and line-to-ground capacitance can result in severe
over voltages.
5. If a phase-to-ground fault occurs on the primary circuit with the
primary neutral grounded, then the phase-to-neutral voltage on the
unfaulted phases increases to 173% of the normal voltage.
6. If the neutrals of the primary and secondary are both brought out,
then a phase-to-ground fault on the secondary circuit causes neutral
fault current to flow in the primary circuit.
ADVANTAGES OF THE D-Y CONNECTION:
1. One of the major advantages of the D-Y connection is that it provides
harmonic suppression. Recall that the magnetizing current must contain odd
harmonics for the induced voltages to be sinusoidal and the third harmonic is
the dominant harmonic component.
2. Another important advantage of the D-Y connection is that it provides
ground current isolation between the primary and secondary circuits.
3. A transformer-connected D-Y with the neutral of the Y grounded is
sometimes referred to as a grounding bank, because it provides a local source
of ground current at the secondary that is isolated from the primary circuit.
Re: Vector group
05/20/2008 1:21 AM
Thanks for your valuable information.
Anonymous Poster (1); badar (1); shefiqka (1)
