Previous in Forum: Fault current   Next in Forum: Vector group
cable size
05/19/2008 7:06 AM
Hi,
Can anyone please let me know how to select a cable based on its total connected load, i have selected a 4 core 185mm for 300amps incomer please let me know am i right or wrong
thanks.
Good Answers: 230
Re: cable size
05/19/2008 7:42 AM
Hello ahmed952
You have failed to advise some vital information:
  1. Voltage
  2. DC
  3. If AC, Number of phases
  4. If AC, The frequency
  5. Other - Advise please
Type of cable:
  1. Lead covered
  2. Rubber
  3. Silicone Rubber
  4. XLPE
  5. Steel Wire Armoured
  6. Steel Tape Armoured
  7. Oil Filled
  8. Paper insulated
  9. Other - Advise please
Type of installation:
  1. Desert sand
  2. Undersea
  3. Heavy clay
  4. Gravel
  5. Loam
  6. In a conduit or pipe (Advise the pipe material)
  7. On a Cable Tray
  8. Vertical or horizontal orientation
  9. Ship
  10. Other - advise please
Climate:
  1. Hot Sahara or Middle East
  2. Antarctica
  3. Monsoonal
  4. Other - Advise please
Barometric pressure range - Minimum to maximum
There are other specifics needed, but those should do as a starting point, which is why you need to check the Maker of your particular cable, check their cable charts, or ask their Engineers for specific advice - After all, they should know their own cables better than anyone else, and there are significant variations between the "same cable" as made by different manufacturers.
Reply here, with
Kind Regards....
Re: cable size
05/19/2008 8:34 AM
Thanks for ur response.
The details are as follows its for 3 phase AC current, 230v, xlpe/swa/pvc cable , supported on a cable tray for a cooling plant in middle east, frequency is 50hz , atmospheric weather varies from minimum 20 deg/c to maximum 50 deg/c.This cable is required as an incomer from the main distribution board for low voltage(L.V) for a building. If you require more information you can mail me.
Thanks a lot .
Good Answers: 42
Re: cable size
05/19/2008 4:07 PM
Hi ahmed952,
This subject matter was discussed in this very same site many times. Now Sparkstation has given the detailed data requirement for selection of cable with de rating factors . Still you cannot understand what he said.
Re: cable size
05/21/2008 9:13 AM
Dear Mr. Abraham.
Thanks for sharing. its a very vital info link.
regds
Good Answers: 230
Re: cable size
05/21/2008 9:01 PM
Hello V.I.Abraham
I've given you a GA point, for that answer plus the excellent weblink.
Kind Regards....
Re: cable size
05/19/2008 7:48 AM
Is this for copper or for wet string?
The Institution of Electrical Engineers maintains and publishes a wonderful thing called the Wiring Regulations that covers this very thing.
Register to Reply 6 comments
ahmed952 (1); nesubra (1); PWSlack (1); Sparkstation (2); V.I.Abraham (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
