Previous in Forum: High Sulphur Diesel   Next in Forum: Looking For Munsell Color Equations
11 comments
90/10 Copper / Nickel Wire
05/20/2008 10:54 PM
Gentlemen, looking for a source of 90/10 copper nickel wire prefereably in 2.4mm (3/32") diameter for thermal spraying. Around 120kg worth of wire
Any suggestions for a relaible source would be much appreciated
Pathfinder Tags: wire supplier
Re: 90/10 Copper / Nickel Wire
05/22/2008 4:57 AM
Metallisation in the UK can get this wire for you. Alternatively, if you contact us, we will put you in contact with a local distributor who may be able to help.
2.4mm may be a bit tricky for this amount. 1.6mm would be more usual as a thermal spray wire. It would also help if you confirm your preferred packaging method (MIG reels, coils etc.)
Good luck
Milty.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
05/22/2008 6:09 AM
You don't specify the purpose of thermal spraying some other material with 90/10 CuNi, and do not clarify if you want just 90/10 CuNi (CuNi10 according to European designation) which is an alloy wire used almost exclusively for manufacturing electric resistances, or for pressure/corrosion resistant service in which case, the usual most similar material is CuNi10Fe, with a small Fe addition (about 1%). This last material is usually welded with CuNi30Fe (30% Ni) which is classified as rod and wire welding in AWS A5.7 (ASME SFA 5.7). No pure 90/10 welding wire is classified under AWS nor European standards. CuNi10Fe isn't classified under AWS, but is by DIN 1733 (S-CuNi10Fe) and BS 2901 (c16) and you can find it just in few western filler metals manufacturing companies. You'll find it in Böhler-UTP, which has distributors all around the world. You can find it in some Chinese companies.
Regarding size. 2,4 mm (3/32") is a common size for MIG welding wire.
Best regards
05/22/2008 6:15 AM
Great answer with loads of details.
My comment regarding 1.6mm relates mainly to metal spray wires. 2.4mm is, as you say, a standard for welding wire. However, due to surface finish and residual surface coatings, welding wires do not always metal spray well.
Good Answers: 25
05/22/2008 6:45 AM
You're right, welding wires do not always metal spray well but I don't think in this specific case surface coatings be a problem as for example copper coating in carbon steel wires.
Best regards
11/09/2020 1:07 AM
Hi ,
I would like to weld Cu-Ni (90/10) alloys with MIG-filler wire (UTP A 387 , 1.2 mm diameter). I have tried with Shielding gas Ar70/30He, 100%Ar and Tri-H gas but i am not able to get satisfactory fluidity, which can fuse the base metal.
Thickness of pipe : 4 mm to 6 mm
Can you suggest suitable welding parameter and shielding gas in GMAW for welding of Cu-Ni alloys?
regards,
Subhash
11/09/2020 3:39 AM
05/22/2008 9:48 AM
"I had not anticipated that the work would present any great difficulites" SHACKLETON
05/22/2008 10:19 PM
Gentlemen, thanks for the responses. the wire will be sprayed on regular carbon steel, packing would be in MIG spools. I am aware that it is not common to spray this, but when a client asks for something....
08/01/2008 12:48 AM
Hi Kiwi Bill,
I can get those ones for you from Turkey from a very reliable source already exporting to many countries and one of the biggest companies of Turkey.
Please email me if you are interested burkiroglu@hotmail.com
Thanks,
Burak Kiroglu
11/30/2010 7:19 PM
Hello,
I have Nickel Wire and these are the specs for 91254 meters.
CR4 Admin - phone number removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
08/01/2008 9:29 AM
www.ArcMelt.com There wire will spray, at that dia., at around 50lbs an hour. Cool stuff.
Register to Reply 11 comments
Anonymous Poster (1); cbjtrust (1); Kiwi Bill (1); Kwetz (2); Milty (2); NiCrMoNoMore (2); SolarEagle (1); subhash535 (1)
