Previous in Forum: ECONOMIC LOADING OF TRANSFORMER   Next in Forum: Capacitor
Heat Energy to Electrical Energy HELP
05/22/2008 8:28 AM
Hi, everyone...
I'm doing a research on how to convert the heat released from a chemical reaction to electrical energy. Do you guys know where do I start... you know books and sites? I have to study whether it's a good option to the company I'm working with, since they waste a lot money from the energy lost from the heat released in this reaction. They have another section on the company that uses a lot of electrical energy, enough for a city with 150000 people for a month. So using the heat lost, converting it in electrical energy and using in this other section would be pretty great. Yet there's a lot to think about, such as the dimension of the equipment needed for the conversion, how much electrical enrgy i'll be able to acquire from the heat energy lost, i was hoping you guys could give a hint as to where i start cause i have no idea.
Anything is helpful, thanks...
Re: Heat Energy to Electrical Energy HELP
05/22/2008 9:00 AM
Easy enough. How about this.
Or this.
Or how about this?
It's all a question of economics, really.
Many years ago a factory turned down a proposal to pre-heat boiler feed water using outgoing effluent, probably on the basis that as the idea was put forward under the Suggestions Scheme, the proponent would have been eligible for a huge payout should the proposal have been invoked. And that simply 'wouldn't do'.
05/22/2008 1:10 PM
How about one you can buy rather then have to build. Contact UTC Power. a division of UTC. They make and market a product that takes waste heat from any source and pushes it through a heat exchanger. The heat exchanger boils refrigerant, which builds pressure and they send this pressurized refrigerant to a turbine which generates electricity.
good luck
05/23/2008 5:12 AM
how much heat loss - are we talking kw or Mw. is it contiuous or intermittent?
A day without a smile is a day lost
05/23/2008 5:31 AM
Indeed, the amount of heat that you intend to recover, and the process you are recovering the heat from is very important. If you are generating Millions of BTU/HR on a fairly continuous basis to melt aluminum, you would have different options than if you were baking bricks.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
05/23/2008 6:28 AM
Start with the beginning:
Every energy conversion step has to comply to some basic rules:
    1. When you go down in the ranking of energy forms the conversion is no problem. (electricity to heat: 100% effective)
    2. When you go up the conversion costs you a certain amount of energy. This efficiency is depending on the method you use but as a general the Carnot method is used to evaluate the theoretical efficacy with the reality. Until now no one has created a cycle which was better than the theoretical Carnot cycle.
Important: at which level is the heat energy available? (temperature of the process which you want to cool)
At which level can the heat be dissipated?
Sometimes it is better to sell the heat (if dT is to small) under the form of district heating, or to a secondary process which loves heat (candy factories need enormous amounts of low level heat (100°C is mostly sufficient))
Or even use the heat to support fish farms. (many nuclear power stations are surrounded by fish farms, which ponds are used for cooling)
If your chemical reaction is really at high level and even emitting long wave radiation (Infra Red) you can use special PV cells that convert this radiation into electricity.
the moral of the story: figures, figures and figures.
05/23/2008 7:37 AM
For low cost and durability try www.electratherm.com
Complete units available 30-500 kW
Register to Reply 6 comments
donnyreno (1); Gwen.Stouthuysen (1); Labyguy (1); peterd (1); PWSlack (1); Shawn_V_Elect (1)
