Previous in Forum: mp3 and wma formats   Next in Forum: What Are The Top 10 SciFi Movies?
electric power generation
05/24/2008 8:37 AM
we are looking for turbine system provide electricity , heat and may be cooling < the system use dry straw as fuel in dry kiln , steam diven turbine also suitable for runing the electricity generator >
RESEARCHER ENGINEER , AGRO - INDUSTRY FIELD , EXCUTIVE MANAGER - CONSULTANT
Pathfinder Tags: alternative power
User-tagged by 1 user
Re: electric power generation
05/25/2008 8:55 AM
HI Hasan,
I had seen bagasee (crushed sugarcane ) fed boiler generating steam at one of sugar mills near Pune ,India. May be you should approach such boiler mfr and steam turbine mfr and alternator mfr.for generating power.
05/26/2008 11:42 AM
May be the boiler fed by crushed sugarcane is similar to boilers fed by dry straw , so i need the the address of some indian manufacturers and suppliers if possible .
Regards
H. KASHANI
05/26/2008 12:31 AM
Hi dear,
I think ur looking for a samll power plant.
We supply steam turbines.
you can contact us with your steam parameters and requirement of power on ssk@biogreenenergy.com
05/26/2008 1:35 PM
dear guest
STEAM TURBINE : THAT IS EXACTLY WHAT WE NEED TO RUN THE ELECRICAL GENERATOS AND FOR COOLING CHILLERS . PLEASE GO AHEAD .
05/26/2008 11:31 AM
Dear sirs
reuired is steam driven aturbine system suitable to run electric generator , the turbine shall operate by hot water and / or steam , the number of turbine required is more than one , as the electric generators shall be more than one , might be three or more , the power capacity of the generators are not the same , just roughly speaking , 60 kw , 150 kw , 300 kw and might be 450 kw . it depends on many factors
H. kashani
e.mail : lebanonmushroom@hotmail.com
