Previous in Forum: device drivers   Next in Forum: Looking for an obsolete data sheet
Connect a Router to a Secure AP
05/24/2008 11:15 AM
I have a D-Link Access Point at my office and I need to connect some Relays that just have RJ-45 connectors, so I'm thinking in buying a Trendnet Router that has 4 Ethernet Ports, I can make the connection to the Relays, but I must change my connection. i.e. SSID: Work- internet access and office network, print, share, etc
SSID: Relay- only connection to the phisicaly connected relays
Now here is my question, Can I share the internet conection from my AP to my Router? like an AP Repeater or WIFI amplifier?
AP=DWL-2100AP D-Link
Router=TEW-632BRP TrendNet
Popular Science - Weaponology - New Member Popular Science - Evolution - New Member United States - Member - New Member
Re: Connect a Router to a Secure AP
05/25/2008 1:48 AM
I thought the AP was to be pluged into a router to give you wireless access? Do you just have a Cat5e cable coming into your office with the AP hooked to it? If so, that cable is coming from a router or switch already. No need to buy a router then, just buy another switch.
You would then install the switch you buy on the end of the cable coming into your office and plug the wireless AP into that with a short Cat5e cable. Instantly up and running.
My old setup: Cable modem -> router (which has 4 ports)
Lack of access ports, so:
New setup: Cable modem -> router -> 8 port switch
Now I just plug everything into the switch and it handles the switching for me. I bought this one: http://www.dlink.com/products/?sec=0&pid=495
DGS-2208 > 8-Port 10/100/1000 Desktop Switch
Ran out of access ports at my shop too, bought a d-link switch and ran a cable from it to the router and started plugging my other equipment into the switch. Love it.
Switches are great!
Ken
05/25/2008 5:34 AM
thanks ken for your answer, but what I want to do is to connect with out any cables the AP to the Router.
Something like this
Modem -> Switch (for some wired connections I have) -> AP (wireless) -> Router (if posible -> General Electric Multilin Relays
Because the floor with the Relays is not wired.
Thanks again.
Cristhian De la Reza
05/25/2008 9:52 AM
Hello Cristhian,
You have your order wrong. The following diagram shows the correct order like I stated. The router has to be installed next after the router. (if it going to be used as a router) Then the AP. You could plug both the AP and the switch into the router. But 1st thing into the modem is the router.
Then you could use a 2nd DWL-2100AP on the floor above or below (wherever the GE switches are) to run the GE switches. I take it you are using something like their DGT switches.
Your only internet connection to that floor would be wireless then.
But it would require the 2nd DWL-2100AP to do what you wish to do, if I am reading their info on their website.
http://images.dlink.com/products/DWL-2100AP/DWL-2100AP_diagram.jpg
But I think your 1st AP is going to have to be hardwired. So, another $100 to get a 2nd one for the other floor.
Regards,
Ken
05/25/2008 8:05 AM
I think you need a bridge and not an access point. I tried this before and the access point only allowed one MAC address to pass.. linksys used to sell a "WET", not sure if they still do..
Register to Reply 4 comments
Anonymous Poster (1); cdelareza (1); MrChevy (2)
