S. Hutchins writes:
Our company makes polyurethane floats used in the measuring of gas and oil levels in hazardous areas. In order to obtain hazardous certification the floats must have a surface resistance of less than 10^9 so that they can dissipate a charge.
The floats are molded with 15lb density 2 part thermoset polyurethane foam. The polyurethane creates a hard skin on the outside of the float making it very durable while the inside of the float is opened cell giving it good buoyancy.
I am having difficulty finding an antistatic additive the can be mixed into the foam during molding, or a durable surface coating that can be applied after molding to give the float the antistatic properties required. Any insight or help to this challenge would be appreciated.
