Previous in Forum: IC Engine: Why four valves instead of two?   Next in Forum: Cylinder sleeving for Engine repair?
tyre markings
05/25/2008 11:31 AM
i just read a post by this guy who referred to the tyre markings on his mercedes and they made absolutely no sense to me.This might be due to the different systems used in different countries.i think this is a good opportunity to discuss the different terms used in our respective countries/systems so we can better understand in the future.
heres the typical denomination in india:-
1) P235/75 R15; Treadwear 480 Traction AA Temperature A (this is uniform tyre quality grading); 105 S (service description); plus of course the manufacturer's name and the tyre name
-The P designates that the tyre is a passenger vehicle tyre. Some other designations are LT for light truck, and T for temporary, or spare tyre
-235 is the width of the tyre in millimetres (mm), measured from sidewall to sidewall.
-75 is the aspect ratio.i.e tyre height is 75% of width.(tyre height not rim dia.)
-The R designates that the tyre was made using radial construction. other tyres are made using diagonal bias (D) or bias belted (B) construction
-15 designates the rim diameter.
-the tread wear no. is only a rough indicator since noone knows what conditions you ride under.but higher the no. longer your tyre will last.
-Tyre traction is rated AA, A, B or C. It does not indicate the tyre's cornering ability
-The tyre temperature ratings are A, B or C. The rating is a measure of how well the tyre dissipates heat and how well it handles the buildup of heat.
-service rating has two parts first one corresponds to load rating and second to speed rating.both nos. have to be tallied with charts to get actual figures.
This might seem stupid to the pros but im sure there are some amateurs out there who might find this useful.
pineapples hate me.its ok i dont fancy thm that much anyway.
Re: tyre markings
05/25/2008 11:03 PM
very helpfully information shaky1367
Don't forget the production date year production week placed in a oval ex. 0802, YY-WW, (2008 week 02)) it might be usefully if some body buys "new" tires.
www.symvoulos.net
Re: tyre markings
05/26/2008 2:19 AM
Also important...the DOT code includes date of mfr. This is how dealer's sales people know when to recommend replacement of a tire even in very good condition and with little or no tread wear.
Re: tyre markings
05/26/2008 10:48 AM
excellent illustration.am i to understand these codes are uniform the world over??
Re: tyre markings
05/26/2008 11:57 AM
For the most part...except parts like US govt mandated DOT coding...unless required in a particular country.
Register to Reply 4 comments
