Previous in Forum: Runing Generator by hydralic power   Next in Forum: PFC-UPS
Solar Pump
05/26/2008 7:10 AM
Who can furnish me the information on Solar Pump Maker ?
This pump should be in a position to lift sump water to first floor and another similar pump should lift the water from first floor to terrace with the help of Solar Energy.
Re: Solar Pump
05/26/2008 12:52 PM
www.sunpumps.com
www.shurflo.com
www.marchpump.com
www.lorentz.de
www.conergy.us
www.homepower.com , Jun / Jul 2008 issue, page 74, has a nice article on solar pumps.
Good luck,
James
" adapt, improvise, overcome "
Solar Pump and relevent URLs furnished by Hastingelewctric
05/27/2008 1:47 AM
Dear Sir,
M/S Hastinselectric has furnished an invaluable information through various URLs on Solar Pumps.
Within such a short period when we are getting excellent feed back thanks to CR4's efforts that through www.cr4.globalspec.com such helping talent is given a golden opportunity to serve the engineer brothers in distress.
Regards,
Ulhas Pradhan
Re: Solar Pump
05/26/2008 11:58 PM
If it is for India location Surya Solar located in Coimbatore and Central Electronics Limited could be useful. Hyderabad and Bangalore have a number of companies installing solar pv pumps. Local yellow pages can be helpful. There are solar thermal pumps you can consider which begins to operate once the sun comes up and keeps on pumping till the sun sets and this works on the heat difference and uses no external external power. These can be be very economical and trouble free.
Re: Solar Pump
05/27/2008 1:27 AM
Very thankful to CR4 through which we received the Solar Pump informastion from Mr. Krishnamoorty .
The information furnished is excellent one and the Solar Thermal Pump concept is new to me and quite educative one.
Re: Solar Pump
05/27/2008 10:59 AM
The solar thermal pump mentioned by a previous correspondent is quite usually referred to as a "hot air engine" or a Stirling Cycle engine and was first used as a water pumping device in the late 18th century (the devices are over 150 years old). I suggest that you "google" "hot air engine" or Stirling Engine for more details. The main limitation here though is that they are generally very big for a relatively low output, so you would usually be far better advised to seek a solar power/electric pump combination. Mono Pumps manufacture a solar solution that uses a small progressive cavity pump that provides a useful output and does not require a lot of space.
Having a farm is great provided you don't have to depend on it for a living.
BigPete (1); chandu krishnamurthi (1); hastingselectric (1); umpradhan (2)
You might be interested in: Lift Tables, Solar Water Heaters, Solar Mounts
