Previous in Forum: 33 mm plate in tanks   Next in Forum: lowering AHU discharge temp by 1 deg. C
Derating-Crane
05/26/2008 8:51 AM
I load tested a 18 tons capacity swl pedestal crane in line with API RF 2D.However,the crane could not hoist up the static test load of 22.5 tons but could hoist at 16 tons when the load was reduced.What will be the derated SWL for this crane and at what criteria.
Re: Derating-Crane
05/27/2008 3:52 AM
16 tons.
Good Answers: 183
Re: De-rating-Crane
05/27/2008 4:23 AM
The static test load should have been 22.5=1.25*Rated load according to your data.
Apply same equation for derating considering the static test load as 16 Tons. Due to uncertainties about loads the rated load has to be always so chosen that the lifting can be done thus the 25% margin.
Re: Derating-Crane
05/27/2008 7:28 AM
You should not just derate the crane. Please check its condition, why it is not lifting designed 22.5 Tonne test load?. Is there any major problem it its drives,brakes etc. If everything is o.k then derated capacity should be 12 Tonne. Suresh Sharma.
Re: Derating-Crane
05/28/2008 1:07 AM
You should refer to the manufacturer's specifications and limitations applicable to the operation of crane. If manufacturer's specifications are not available, a qualified engineer competent in this field can determine depending how old of the crane and on its condition and as such should be appropriately documented and recorded. Some countries will base on how long the crane in operation, and in most of the time I had encoutered pro engr in this field derates to 80-50 percent of the crane.
" Almost anything can be reversed through Engineering but not Human Life " WorKerZ
Register to Reply 4 comments
Anonymous Poster (2); nick name (1); WoRkerz (1)
