Previous in Forum: ladder logic for level transmitter   Next in Forum: Level Indicator for Dry Lactose - Sanitary application
AIR SET & ACTUATOR IN CONTROL VALVE
05/27/2008 12:25 AM
How to select the bench range for actuator.
And How should we select the set pressure value for the AIR SET used in Control valve accesories
Re: AIR SET & ACTUATOR IN CONTROL VALVE
05/27/2008 3:46 AM
Refer to the actuator manufacturer's instructions.
07/12/2008 12:34 AM
You have to know your process characteristics, such as shut off pressure, then you can do your bench set.
Register to Reply 2 comments
