Previous in Forum: i would like to find out SIM card   Next in Forum: Noise in my signal?
static routing with cisco routers
05/27/2008 3:13 AM
please provide me solution for the below:
how to perform static routing configuration for the toology given below
router1: e0:172.15.5.1
s0:201.15.5.1
pc1: 172.15.5.2
router2: e0: 50.15.5.1
s0: 201.15.5.2
pc1: 50.15.5.2
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: static routing with cisco routers
05/27/2008 8:22 AM
You have to adjust your cisco due to manual.
Using HyperTerminal for windows either minicom for linux send to cisco appropriate script commands (in case your cisco has not yet IP address so you need make initial connection through com port). As rule cisco has factory IP (if someone didn't destroyed it yet) so you can communicate with it by means telnet or ssh protocol to send its script commands. Like ->show running-config
As I could understand you have here three network interfaces to be done. Just read manual throughly and do your work.
If your cisco has web-interface for its adjusting --- you're lucky guy, though it's not safely for security matter, but easy to use.
I think it would be more suitable for you to visit cisco site either cisco devoted forums.
Good luck.
03/12/2018 12:17 AM
Hi I'm Linda Zhu from CHR International Limited . Our company could provide New Sealed Original Cisco Products with clean smartnet. If you have any question, you could tell me free. My whatsapp: +86 159 1404 9076
08/27/2026 7:32 AM
Static routing is one of the best topics for building a strong understanding of how routers make forwarding decisions. I think the most useful way to learn it is by configuring a small lab with multiple routers, adding routes manually, and then testing connectivity with ping and traceroute. Troubleshooting incorrect next-hop addresses or missing return routes also helps make the concepts much clearer. For anyone preparing for Cisco networking certifications, hands-on practice with static and default routes is definitely worth spending time on.
Register to Reply 3 comments
annazhu1986 (1); caramba (1); exams4sure (1)
