Previous in Forum: spong iron production cost   Next in Forum: Electric Heaters
HVAC chemicals treatment
05/27/2008 3:27 AM
what about sodium nitrit in HVAC system
Re: HVAC chemicals treatment
05/27/2008 3:30 AM
05/27/2008 5:06 AM
Sodium nitrite is used as an oxygen scavenger.
Good Answers: 38
05/27/2008 11:53 AM
Sodium nitrite, generally combined with borate for pH control and azole for non-ferrous metal protection, has been a staple of the water treatment industry for many years. Nitrite provides good corrosion protection when maintained within the optimum levels, usually 800 to 1200 ppm NaN02, but actually increases corrosion when maintained at levels below 500 ppm. Higher concentrations of this product, mainly because of the resulting higher pH, have been found to cause pump seal damage. Nitrite is also a contributor to bacterial growth within the system, and should be replaced with a non-nitrite product if bacteria is encountered. Antimicrobial agents are also often used in conjunction with closed system inhibitors; but must be products formulated and labeled for use in hot water recirculating systems.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Anonymous Poster (1); charsley99 (1); PWSlack (1)
