Previous in Forum: X ray unit to compressor   Next in Forum: Grounding test lead lengths
Spice software
05/27/2008 10:59 AM
Hi
Does anyone know of any spice software for modeling AC ccts. I know there is heaps of software out there that can model small signal ac ccts but am looking for something to model slightly higher current systems. The problem I find with most spice software is that you can specify good ac voltage ac sources, eg 220vRMS 60hz
Any help would be greatly appreciated
Thanks,
Tom
Re: Spice software
05/28/2008 8:39 AM
Dude, just google spice. you will find several...
Re: Spice software
05/28/2008 10:03 AM
If you are looking to model AC systems, you may wish to investigate EMTP. Electro-Magnetic Transients Program. You will want to check out Dr. Meyers version called ATP.
http://www.emtp.org/ Licensing to use ATP is free of all charge for all who have not engaged in EMTP commerce. (from the website)
There is also a commercial version that will cost you thousands of dollars.
http://www.emtp.com/ ($$$$)
I used Dr. Meyers ATP-EMTP to do my simulation for my masters thesis. I was simulating a resonant three-phase inverter. The program works well and I recommend you check out the first link to see if this program will work for you.
Good luck with your quest.
Re: Spice software
05/28/2008 10:24 AM
Thank you ! This is exactly what I have been looking for !
Best of luck to you too
Tom
Re: Spice software
06/01/2008 11:34 AM
Go to www.tier-2-innovation.com and see if microcap9 can help. The evaluation version is free but limited.
Re: Spice software
06/01/2008 2:53 PM
Thanks for the help, will definitely have a look
Cheers,
Tom
Anonymous Poster (1); Brave Sir Robin (1); Frank12 (1); Tommish (2)
