Previous in Forum: Engine starting_electrical   Next in Forum: lpg convertion
20 comments
United Kingdom - Member - New Member Engineering Fields - Energy Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Fans of Old Computers - Commodore 64 - New Member Technical Fields - Technical Writing - New Member
Novel Use for Fuel Injection Pump
05/29/2008 4:58 AM
Hi CR4,
This is not strictly an automotive topic, but I was hoping some of you gearheads would be able to point me in the right direction. I have a pumping requirement (for a refrigeration system) that may be well suited to a fuel injection pump. I need to raise the pressure of my working fluid from 10 bar to 30 bar (150 > 450 psi) The temperature is about 100 deg C and the flow rate is pretty small (~0.5L/min) Usually petrol fuel injection pumps are rated for about 10bar, and diesel fuel injection pumps about 1300 bar. I have however discovered that GDI pumps (gasoline direct injection) are rated between 50-200 bar. Does anyone know how these pumps work and/or where I could source one ? (pref in the UK). I have suffered problems with cavitation before (fluid vapourizing inside the pump). Presumably fuel pump are designed to prevent this occurring. Are they positive displacement, piston type pumps ? Any info/guidance would be greatly appreciated.
Thanks DesEng
Those who believe in telekinetics, raise my hand - Kurt Vonnegut
Pathfinder Tags: fuel injection pumps
Re: Novel use for fuel injection pump
05/29/2008 5:20 AM
It sounds as though a gear pump of some sort would do the job. Here's a picture of the innerds of one:
Gear pumps are positive displacement and the flowrate is closely related to the rotation speed. Any excess pressure at the delivery end of the pump can be returned to the inlet reservior via a pressure relief valve and a spill-back pipe.
'Owzat (a Cricket term, for the uninitiated)?
05/29/2008 5:37 AM
Hi PWSlack,
Thanks for the quick response.
We have tried a gear pump already, and cavitation is an issue. This was either caused by the high rpm of the pump or the heat generated by the gears. The fluid being pumped is recently condensed and so any sudden drop in pressure causes flash evaporation. I really need a slow reciprocating pump or other novel solution.
05/29/2008 5:45 AM
Cavitation is caused by a pump working sufficiently hard for the liquid either at the inlet or inside its casing to fall below its boiling pressure at that temperature.
Try cooling the liquid before it hits the pump, perhaps?
Try increasing the inlet pipe size, perhaps?
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
05/29/2008 9:52 AM
Hi des-eng,
Can you allow the condensed fluid build up in a small accumulation vessel. If you can, you would have lower volume change and therefore wouldn't drop the pressure as much as you were pumping. Also, (I'm assuming you know this, but just-in-case) is your pump the lowest point in the system?\
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
Good Answers: 97
Re: Novel Use for Fuel Injection Pump
05/30/2008 12:06 AM
Try geared oil pump for VW 1600 air cooled engine, same principle, cheap and easy sourcing.
Good Answers: 15
05/30/2008 12:21 AM
Most engines would be the same wouldn't they?
The Toyota 4A series are similar
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
05/30/2008 12:48 AM
Design Engineer, Try researching the "Tesla fluid pump", also known as the "boundary layer drag effect pump". It is used when shear is unacceptable and it does not cavitate.
Many airport fire departments use them as pumps for retardant foam.
It can be easily scaled for size, and it is very simple to build.
Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Good Answers: 97
05/30/2008 2:17 AM
GA
05/30/2008 5:55 AM
Hi Dragonsfarm,
The Tesla turbine is a very interesting principle, but I'm not sure if it's suitable for my application. I need 300psi pressure rise with low flow rates (~0.5L/min). Data on the pump is sparse and I cannot find any companies who manufacture tesla pumps.
The bottom line is that I do not have a development budget for this aspect of the project and so I am hoping to find an "off the shelf" solution. Many thanks for your suggestion.
05/30/2008 6:08 AM
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
05/30/2008 7:44 AM
bwire is on the right track. An oil pump would do the trick. Do not use a wet sump oil pump. Source out a dry sump oil pump used in race car applications. You have specified that your application will run temps around 100C. A fuel injection pump will definitely NOT handle that type of temp. A dry sump oil pump for racing applications should bring you up past 500 psi, will handle 100C temps and should not pose any cavitation problems depending on what your flow rate needs to be.
Try here:
http://www.demon-tweeks.co.uk/
Good luck
Dirt is for vegetables. Pavement is for racing.
Good Answers: 11
05/30/2008 8:13 AM
The other problem with using a fuel injector is that they use the fuel they are pumping as a cushion so the parts don't impact. If your liquid has different mechanicla properties from normal fuel you will have life issues down the road.
Eric
Good Answers: 123
05/30/2008 9:37 AM
For an "off the shelf" idea how about a small triplex piston pump designed for pressure cleaning. Use whatever motor is compatible with the work source you are at. Good luck.
Bob
05/30/2008 10:04 AM
doesn't matter what product you use the cavitation problem will continue unless you can get your hands on the high pressure pumps used to pump #2 fuel oil into industrial 6 nozzle furnaces.
a company in toronto canada called inglis used to make them the name changed a while back to sunstrand inglis or inglis sunstrand. the innards have 2 sets of pumping gears set up in matching eliptical orbits. the pressure was regulated by a allen wrench after a side mounted plug was removed, the wrench was out into the sccrew haed and the pressure was able to be swet any where from mi9n. of 200p.si. to around 400 depending on how the soze of the nozzle.
'da ber
05/30/2008 10:58 AM
May also want to look in to the vane type pump similar to what is used to supply fuel to a gas turbine engine. The ones we had on the GE LM2500 engines on board ship would supply nearly 1,000 gals per hour at full power and over 350 psi, using marine diesel fuel, very similar to #2 fuel oil.
05/30/2008 4:23 PM
Is in some book a fuel injection pump,that's used in fridges or hydraulics.The diesel version is called "excello" or something like that.The hydraulic version is a piston type.In fridges, common ones,are so commons.If all of them works at differents temperatures and pressures and differents ways for lubrication...Why don't try with a common one those you get in any specialized commerce for refrigeration spare parts?
06/03/2008 12:37 PM
All refridge. compressors i've encountered are piston pumps. Automotive AC pumps are cheap and available too, if you project is off grid. So cheap i would not pursue a diesel or gasoline injector pumps. (just my humble opinion) Don't forget the off grid refridge with no moving parts too. (propane burner)
Good Luck,
wooly
Good Answers: 123
06/03/2008 2:03 PM
Is your pumping requirement a long term operation, or simply an occasional need to pump the refrigerant?
Bob
06/04/2008 4:53 AM
Hi Bob,
The requirement is for long term operation.
Good Answers: 123
06/04/2008 11:01 AM
I have a catalog from a company called Hydraulic Supply. They have many styles of pumps that could be used. They are at www.hydraulic-supply.com.
The Aro division of Ingersoll Rand has a piston pump that could be used if you have compressed air available. They are at www.arozone.com.
Eaton / Char-Lynn Hydraulics also manufactures many pumps. They are at www.eatonhydraulics.com This company also manufactures the Vickers brand of pumps.
Hypro pumps manufacture pumps of many types. They are at www.hypropumps.com. They manufacture some small displacement piston pumps that have ceramic plungers that should survive your refrigerant's chemical nature.
Hydura Products, Hydreco, John S. Barnes Corporation, also manufacture pumps that might be workable for you. I do not have web sites for them, but I'll bet you know how to find them.
As I was looking I did not find anything pre-made that had the volume and pressure that you wanted combined into a pump-motor combination. But if you have compressed air available where the pumping needs to be done, I feel that one of the Aro piston pumps would be easy to set up to perform exactly as you need. Use an air pressure regulator to limit the maximum discharge pressure, and air volume control to limit the speed of pumping so as to keep the suction pressure high enough that you will not bring on cavitation. Hope this helps. Just my mind running unchecked.
Bob
Register to Reply 20 comments
Anonymous Poster (1); bob c (3); bwire (2); ca1ic0cat (1); design-engineer (4); Dragonsfarm (1); ferquiza (1); mikey (1); PWSlack (2); rickmoore69 (1); Snaketails (1); unclefastguy (1); wooliver (1)
