Previous in Forum: Consigning CO2 to the Ocean Floor   Next in Forum: STAINLESS STEEL
12 comments
Bearing Grease
05/30/2008 9:14 AM
Can anyone help me with bearing grease. I am working on a project for an automatic lubrication system and would like to know the ideal amount of grease & frequency required per bearing. The bearings are SKF 5311 size, in a pump running 1750 rpm pumping sulfric acid (not in contact) 24 hours a day, 7 days a week.
Sh** doesn't just happen, we engineers make it happen!
Pathfinder Tags: Bearing Grease
Re: Bearing Grease
05/30/2008 9:40 AM
I forgot to add the recommended grease is number 2 lithium base grease at operating temperatures up to 220 degress F.
Re: Bearing Grease
05/30/2008 4:30 PM
Use the Bearing Relubrication software here:
http://www.newstandardinstitute.com/catalog_reftools.cfm
Good Answers: 88
Re: Bearing Grease
05/30/2008 4:34 PM
"Can anyone help me with bearing grease?"
Sure can! How much you got? Do we have far to go?
Good Answers: 183
Re: Bearing Grease
05/30/2008 5:41 PM
Why not ask SKF?
This company is one of if not the biggest bearing manufacturer and they have all necessary informations due to their very broad and deep research.
They could be the best source for the information you need.
Re: Bearing Grease
05/30/2008 11:05 PM
From the field:
Contact Applied IND. Technologies they have a grease canister that screws into you grease Zerk fitting and you choose the rate of flow to the bearing. They are trick and work great. The company was called something else but Applied bought up a lot of bearing house across the country.
If you can not find them email me direct and I will have someone contact you direct.
miketheboilerguy@aol.com
Thanks
Mike
Re: Bearing Grease
05/31/2008 7:50 AM
if you wont an auto greaser you should contact Texas Crushers System @888-579-2139. Ask for A. T. or Eileen Thrasher, We should have some in stock, if not take about two days to have ready to ship.
Re: Bearing Grease
05/31/2008 9:35 AM
Timken has a very good lubrication guide on their website.
Re: Bearing Grease
05/31/2008 12:05 PM
www.lubesite.com/ has a complete line of high quality lube feeders.
Re: Bearing Grease
05/31/2008 4:02 PM
google Alemite Lube Products and search for Visi-lube part # b1741a.
Re: Bearing Grease
06/01/2008 1:41 PM
Use Schaeffer #02742 bearing grease. It will double the life of the bearing.
Call American Industrial Resources @ (440) 759-7257. They handle all types of grease delivery systems. They also design, install and service industrial accounts accross the US. Their charges are also very reasonable.
THEOILGUY55
Re: Bearing Grease
06/02/2008 4:04 PM
Friends may bear gifts. Beware of enemies bearing grease!
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
Re: Bearing Grease
06/03/2008 8:31 AM
Contact: John.P.Baker@skf.com
He'll be able to help you. He works in the after market and has over 30 years of experience with bearings.
John J Baker
Register to Reply 12 comments
Anonymous Poster (4); bakerjohn (1); Mag (1); mcarlson (1); millrat (1); nick name (1); rdavis (1); THEOILGUY55 (1); user-deleted-13 (1)
