Previous in Forum: Bearing Grease   Next in Forum: Pouring cold water on "Global Warming" climate report
STAINLESS STEEL
05/30/2008 2:35 PM
WHATS THE CORRECT ROD CHOICE FOR REPAIRING A CRACK IN STAINLESS NO PRESSURE TANK?
Hobbies - CNC - New Member United States - Member - New Member
Re: STAINLESS STEEL
05/31/2008 8:58 AM
It depends on the type of SS you are welding and the processes you have to work with. It is considered the best choice to match the filler metal to the base metal. Contact a local welding supply company and tell them what type of SS you have and if you will be using MIG, TIG, or SMAW for the repair. It is in their best interest to supply you with the correct rods. Otherwise next time you will likely take your business elsewhere.
