Hello all. I thought I would share something gleaned from beneath a shady oak tree near my driveway. The vehicle of interest is a 1995 Nissan XE pickup with a 2,4 liter engine, five-speed transmission, and four-wheel drive. I purchased the truck as a used vehicle during 1999, and it now has about 212,000 miles on the odometer.
The cooling system for the engine seeped coolant for years, and the source could not be found. Recently, it overheated (no damage-turned on the defroster full heat, full fan) and got it home. I addressed the usual suspects; (a) thermostat, (b) water pump and gathered these items at the local parts store. I also purchased a complete timing chain, sprocket, guide rail and tensioning rail set complete with a new tensioner. I understood that the recommended replacement interval for these items is 105,000 miles, and I was more that twice that distance.
Fuel prices being what they are, I think it is most important to keep this truck's engine in an absolutely good state of tune. So, I begin my work on a beautiful Saturday morning and first remove the radiator to gain better access. Wow-found the source of the slow coolant seep that eluded me. It was the area around the bottom of the cooling fin block where it is crimped to the lower water jacket. So I stop my work and borrow a car so I can buy a radiator. I've carried large things on a motorbike, but I did not have a bungee net that was large enough to secure a radiator box.
Long story short-I carefully make notes about the relative positions of the crankshaft, camshaft, and distributor rotor, and proceed to remove the "worn" parts. I remember something from my early days when I owned a couple of Triumph sports cars regarding how to determine the wear level of a timing chain. Essentially, pull the chain taught and measure the span between as many rollers as possible with a vernier caliper. I then compared my finding to that of the new chain. No difference!
I measured the root diameter of each sprocket and compared old to new. No difference! The only items determined to be worn were the tensioning rail and the guide rail. The latter was broken in half, and both were heavily grooved. In the end, the only parts I could prove to be faulty were these rails. A worn guide rail would allow a very slight retarding of the camshaft-perhaps a degree or so. And it was natural wear.
So in the end, I could have driven this truck probably 200,000 more miles before the timing sprocket and chain set were worn to the end that the camshaft was retarded. So, I now have a thirteen-year-old truck that has a new timing chain set and a new cooling system. The timing chain replacement was absolutely unnecessary. Of course one could say that about my replacement of the functioning water pump as well, but for $45.00 I do not have to replace it later.
Has anyone else ever replaced perfectly good parts with new parts just because it was recommended by the manufacturer? Is this a common occurrence? Note, I do regard a timing system that uses a toothed rubber belt very differently than one that uses a steel transmission chain.
Best Regards,
Ing. Robert Forbus
