Previous in Forum: Generator Using its Heat to Heat a House?   Next in Forum: What type of flowmeter is good for measuring LPG-details given
flame retardent hay bales
06/01/2008 9:27 PM
I am creating a display using hay bales. I have been informed they need to be treated to be flame retardent. What do I need and how do I do it?
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: flame retardent hay bales
06/01/2008 10:51 PM
Google 'straw bale house'. I saw a show about that on discovery channel, I think. It was something real common they used as flame retardent. I just cant remember and I'm too lazy to do your research.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
06/01/2008 11:08 PM
Set up some type of water sprikpler or wet them and then use a soaker hose snaked around them to keep them wet is my best answer; but they will start to stink bad when the water is removed so get rid of them fast after the display is done.
In the winds the edges will dry out so let gravity work.
06/02/2008 12:33 AM
06/02/2008 4:30 AM
Theatrical equipment suppliers may have the materials needed, as fire retardent coatings are used throughout the world in this field. Given the high surface area of a hay bale, a lot of it may be needed.
Having tried to extinguish a burning hay bale, don't skimp on it.
Register to Reply 4 comments
dadw5boys (1); jdretired (1); PWSlack (1); Shadetree (1)
