Previous in Forum: motor control system   Next in Forum: why generation
DIW WATER
06/02/2008 6:40 AM
what is differnce between normal water and diw water? why its is used in reactor cooling?
Re: DIW WATER
06/02/2008 6:50 AM
<...what is differnce between normal water and diw water...>
Its conductivity, and the levels of organic and biological contaminants present.
Good Answers: 101
Re: DIW WATER
06/05/2008 12:15 AM
DI water contains no dissolved minerals. The reason it is used for cooling systems is because the lack of dissolved minerals means that there will be no scale buildup along the pipeline walls.
Register to Reply 2 comments
You might be interested in: Cooling Tunnels, Electronic Cooling Fans
