I forgot my password.
Don't have an account?
hello. i have high fuel pressure on a caterpillar d398B could you tell me if there is a valve in the system that might create this?
Thanks david
the CAT 398 is phased out you may not find any information on D series engines if you persist with Caterpillar they may charge a fortune to help you.
crm
Ex Caterpillar
hello crm,
I noticed that you are an ex Cat.
I have few CAT 3512 BTA engines ( Actually 8 in one room).
We have an issue of high winding temepratures ( upto 108 deg C) and also high engine room temeperature ( 55 deg C)
Is there any calculation to find out how much opening is required in the engine room to enable enough ventilation and for combustion air.
Here in Saudi ambient temperatures can go as high as 49deg C.
Any inputs will be appreciated,...if you need any more info let me know..
Cheers.
Dear chatterpillar yes very much send me your E-mail ID ishall sed you its slightly large file
