I am trying to use PAO oil to cool some equipment. I currently have 1/4" metal tubes and brass compression fittings. As feared, the oil loves to leak through the tightest seeming connections. We could try to use teflon, tygon or other plastic tubes, but I fear that the "push on" tube to metal connections would leak just as bad, if not worse. Temperatures are expected to remain under 100 C. There will be vibration in the equipment. Googling this is a bit of a problem due to the huge number of similar but not quite the same problems people have with synthetic oil in personal and race cars. I would appreciate any suggestions on metal vs. plastic tubes, compression fittings, "push on" fittings, the "flare the end of the tube" style of fitting, rubber/plastic gaskets, liquid/gel gaskets (brush on Permetex?), filling the compression fittings with epoxy (maintenance nightmare), etc. Off the shelf solutions are great, but I do have access to a machine shop if that is necessary.
Thanks,
Bruce
