Previous in Forum: Steel Skywire - Short Circuit Capacity   Next in Forum: Books About Ladder Logic
How Much Hydro Power?
06/05/2008 7:16 PM
Realistically,how much elec. power could one expect, with a full gravity flow of water
in a 12 inch dia. pipe with a 21 foot head using a pellting wheel with a enclosed housing.
Regards Howard
Pathfinder Tags: hydro power
Re: How Much Hydro Power?
06/07/2008 12:53 AM
Dear Anil Tiwari Sahab,
Subject question has already been replied by me in " Discussion " column of CR4 today :7th jun.'08 at about 1018 Hrs.. Please go through it.
Regards,
Ulhas Pradhan
Good Answers: 39
06/08/2008 3:38 PM
Nice reply but how do I go about finding that specific reply among the hundred others posted the same day and in what topic forum. A hot link or better yet, detailed directions would be appreciated.
Elnav
06/09/2008 9:22 AM
Dear Sir,
At the end , it is you , who have to use the descritionary power and select the best amongst the available replies/solutions offered to you spontaneously and with just a strong desire and fire to be helpful to you in your crisis.
So the best of luck to you.
I sincerely feel that this is a golden platform to ask our genuine problems and to be helpful to our engineer fraternity if we know the right solution.
Regards,
Ulhas radhan
Good Answers: 39
06/09/2008 12:45 PM
Hello! I ask for directions to find your posted comment and you answer with this! Where is the post you originally wrote? Which forum? I did not see it.
Elnav
06/07/2008 9:28 AM
From experience about 75 to 100hp if the pipe is full, if the pipe isn't full you probably can't run.
There are less expensive alternative's to a Pelton wheel, such as a canal irrigation pump run backwards, but make sure you engineer the pump thrust bearing housing for reverse thrust during shutdown. A Pelton wheel can regulate to low flows.
If you are an isolated generator, you will probably want a set of back-up batteries connected to the generator output, depending upon how much the flow changes other heat storage methods, etc may be of interest.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
06/08/2008 7:35 PM
Thank you for the information. We currently run 55 and 75 KW diesel generators and I am looking for some alternative in view of the escalating fuel costs.
Thanks to all for the help.
Howard
Regards Howard
Register to Reply 6 comments
bhrl99 (1); CoronaCameraMan (1); elnav (2); umpradhan (2)
