Previous in Forum: Calculating Touch Voltage for Water Heater Element   Next in Forum: EOT Cranes
Medium Voltage Cable Cross-Section
06/06/2008 6:33 AM
how can we calculate the medium voltage cable crosse section
Re: medium voltage cable
06/06/2008 6:46 AM
Measure its diameter, square it, multiply by pi and divide by 4.
06/06/2008 6:54 AM
you need futher than this. How much ampere, at what voltage( only medium wont do), voltage drop, cable below ground, or in air, what material of cable, sigle phase or 3 phase , so many things are involved.
Just go to cable dealer and get standard charts. may be some charts be there in the net.
06/06/2008 7:12 AM
Moath didn't ask that, though.
06/06/2008 7:43 AM
but , it seems he is looking for some elctrical information. Otherwise he could have asked for how to calculate the crossection of a round rod ?
Now when he says medium , and then he says Cable ( not wires), so it could be 3 phase cable. May be 3 phase 4 wire? Now is he looking for outerdia of cable with the insulation or is he looking for cross section of each phase by which a cable is specifiied eg 185sq.mm Aluminium cable for 415Volt supply , 3 phase , 4 wire , below ground installation etc etc. Now when you see the cross section of cable and having multiple strands and each cable bunch is not fully circular - then you know it is not pai/4x square of "d'.
06/11/2008 7:37 AM
Please refer IEC 60287 parts to calculate the diameter of MV cables. The standard said a lot on insulation, metal tape, conductor etc etc. The calculation gives approximate diameter.
BNDas
06/12/2008 6:45 AM
Hi,
Biswanath das is correct. A MV Cable is chosen based on the current to be carried (depends on the circuit application - a CT, a VT, Power or Control circuits). Also, other parmeters shall also be imporant like short circuit current, type of laying, type of insulation.
N.Suresh
Register to Reply 6 comments
Anonymous Poster (3); biswanath.das (1); chakraborty ranabir (2)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
