All cranes are not EOT. EOT , I think stands for Electric Overhead Traction. It is basically a electrically operated hoist moving on rails on a high structure so that it can traverse with load.
Hello friend, Let say, that apart from spending a major amount on buying some big and
significant machinery parts such as Cold rolling mill, induction
furnace, transformer, motor, generator sets, EOT Crane. Thanks for sharing this.
EOT as i understand is Electric Overhead Traveling.A full function crane will have minimum of three functions, cross travel , line travel and at least one hoist.Apart from these we have telphers i.e a mix of chain control and motor driven, semi gantry cranes and skips.
And then the God said" Let every drive be controlled by a PLC"
An overhead crane, commonly called a bridge crane, is a type of crane found in industrial environments. An overhead crane consists of parallel runways with a traveling bridge spanning the gap.This is most common type of overhead crane, found in most factories. As
obvious from name, these cranes are electrically operated by a control
pendant, radio/IR remote pendant or from an operator cabin attached with
the crane itself.
